HT7700 touch-type stepless dimming light circuit
Source: InternetPublisher:李商隐身 Keywords: Stepless dimming touch type dimming lamp Updated: 2021/10/09
The touch-type five-level state light lamp
is made of the HT7700 dimming special integrated circuit produced by Taiwan's HOI (TEK) company.
Through the touch electrode sheet M,
the light is continuously illuminated steplessly
. In essence, the light is It is a 96-level
brightness change.
IIT77. . Manufactured using CML)S
process, standard DIP-S package
, the functions of each pin are as follows:
① Pin zL:, is the AC zero-crossing signal
detection terminal; ② Pin SENSE:
K FY, is the touch sensing signal or keying signal input terminal; ③ pin FB, is the input terminal for the signal current when touching
; ④ pin V, the negative terminal of the power supply; ⑤ pin TRIC;, the trigger signal output terminal, used to contact the thyristor; ⑥ and
⑦ pins are OSC2 and OSC1, They are the oscillation signal output and input terminals respectively, and an external 62kfl resistor is connected;
⑧Pin V West is the positive terminal of the IU source. The power supply voltage range used by the HT7700 integrated circuit is 9-12V.
In the figure, VD3, vS, R, and (1) form a resistor step-down rectifier IU circuit, which outputs about 9V DC working voltage
for the HT7700. When the power is first connected, the lamp E is in an extinguished state. When the human hand touches the electrode sheet M
(You can use the metal shell of the Taiwan Spider). If the touch time is less than 0 7s, the light will change from extinguished to the brightest; continue to touch, and
the brightness of the light will decrease smoothly by 96. After you let go, the light will maintain this brightness. Then use If the time is less than 0 7s
, touch M. The light E will go out. C is an isolation safety capacitor, and a CBB1000V high-voltage capacitor should be used to
ensure the safety of the moon user.
- LED acceleration and deceleration motion display composed of CD4017
- A white light LED power outage emergency light
- Measurement and analysis of automatic emergency lighting circuit
- Design and production of rain control and light control timing controller based on P87LPC764
- SC3071 touch step dimming light circuit
- Simple electronic doorbell circuit
- Lighting audio control circuit
- Motor speed photoelectric control circuit
- Economical and practical delay light circuit
- Fluorescent lamp electronic ballast circuit 11
- Touch type alarm circuit 4
- One of the touch lighting switch circuits
- SS0619 touch step dimming light circuit
- Non-touch touch delay light circuit
- Touch delay lamp circuit using time base circuit (1)
- Touch delay light switch circuit (6)
- Use CD4069 to make touch delay energy-saving lamps
- Use CD4011 and CD4017 to make a touch-type five-speed dimmer
- Bidirectional thyristor stepless dimmer with light stabilizing function
- Use LS7232 to create a touch-sensitive dimming light
