Capacitance meter circuit diagram design based on LM2917
Source: InternetPublisher:3228 Keywords: Circuit diagram design LM2917 Updated: 2020/01/06
describe
The circuit diagram of a simple capacitor using IC LM2917 is shown in the figure. The LM2917 is a high gain monolithic frequency to voltage converter IC from National Semiconductor. The main application of LM2917 is even in tachometer and it can be used in a variety of such applications. Capacitance values from 0.01uF to 0.1uF can be measured using this circuit. The capacitance to be measured is connected between pin 2 of the IC and ground. The output voltage available through resistor R2 will be proportional to CX, which will be displayed by the meter. Resistor R1 can be used to calibrate the circuit.
Circuit diagram
![The <strong>capacitance</strong> meter uses <strong>LM2917</strong>](http://www.eeworld.com.cn/circuit/upload/cbd6ddcb214e3d0dae616dd11847949c/3bdf59690478baab2e8d6e53108e2070.png)
Precautions
This circuit can be assembled on a VERO board.
Resistor R1 can be used for calibration.
Meter M1 should have a 10V voltmeter at the fire department.
The IC holder must be installed.
- Balcony intelligent invisible anti-theft net
- Simple electric tachometer
- Analysis of valid and fault conditions of differential signals
- Multi-speed current test circuit of transistor HFE
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- LM3914 makes car battery detector
- Homemade Metal Detector
- A simple electronic muscle stimulator circuit
- AC ammeter circuit
- Digitally controlled operational amplifier gain circuit
- Machine tool maintenance bearing fault detection circuit
- Induction cooker pot quality detection circuit
- Static electricity detection circuit composed of LM324
- A5348 smoke alarm detection circuit - block diagram
- Light detection circuit
- Long wave infrared detection circuit
- HW200 telephone tester detection circuit
- Film thickness detection circuit using eddy current method
- Light sensor particle size distribution detection circuit
- Gas concentration detection circuit
