Automatic switching circuit for motor Y-△ connection
Source: InternetPublisher:aerobotics Keywords: switching circuit motor automatic switching Updated: 2021/06/09
Working principle of the circuit: In the figure, VD, C, Crown, R2, RP, and £ form a signal sampling
circuit. The main circuit current of the motor is sensed to terminals n and 6 through the transformer £, and
the DC voltage is rectified by VD and filtered by C. Add to R. , both ends of R2 are divided and sent to the comparator
for comparison, and the output signal is sent to VT for amplification to drive JZ. The sampling signal is proportional to the current of
the main circuit of the motor . Adjusting RP, and RP2 can determine the main circuit .
The electrical signal obtained by the secondary side of £ must be above tens of millivolts, that is, it must be greater than
the minimum voltage required by the comparator.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Model rocket launch controller circuit
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- A small improvement on the ordinary refrigerator motor starting circuit
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Squirrel cage asynchronous motor reverse braking control circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Motor self-starting circuit
- Using P110C to control 6 DC motors simultaneously
- An experimental model of an infrared radio alarm
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Switching regulated power supply circuit
- Electromagnet control circuit
- sound control circuit
- Multi-pole leakage protector circuit a
- Automatic tuning control circuit
- Neon light control circuit
- Detection and control circuit of electromagnetic stove
- Video switching circuit diagram
