Triac two-tone dimmer (1)
Source: InternetPublisher:难得正经 Keywords: triac dimmer thyristor power supply Updated: 2020/05/31
In the figure, Hl and H2 are red and green light bulbs respectively.
A potentiometer RP is used to simultaneously adjust
the conduction angles of the thyristors vsl and VS2. RP, Rl, R2 and CI form
the voltage regulating and phase-shifting network of the thyristor VS1, and RP, R1,
R3 and C2 form the voltage regulating and phase-shifting network of the thyristor VS2. After the power supply is turned on , the power supply
charges the capacitors Cl and C2 through Rl and RP (assuming the RP sliding end is at the center) and resistors R2 and R3 respectively. Changing the time constants of (RI+RP+R2)xCl and (R1+RP+R3)
x C2 can change the conduction angles of the thyristors
vsi and VS2, thereby changing the brightness of the lamps Hl and H2.
It can be clearly seen from the figure that when the sliding end of RP moves to the left, the light H1 gradually lights up and the light H2 gradually dims; conversely
, when the sliding end moves to the right, the light H1 gradually dims and H2 lights up again.
- A white light LED power outage emergency light
- Circuit diagram of game score display using 7-segment LED
- Low cost LED automatic emergency light circuit
- Practical sensitive light-controlled switch circuit diagram
- Corridor automatic light-off device
- One of the bead-type emergency light circuits
- Gift lamp music box circuit
- One of the circuits that control one light in multiple placesb
- Electronic rapid starter for fluorescent lamps
- Bedside lamp controller circuit
- A very creative voice-activated light circuit diagram to prevent false triggering
- SCR control buzzer circuit
- Disconnected anti-theft alarm circuit (2)
- Switching circuit consisting of oscillator and triac
- Single-phase series motor speed control circuit using triac
- Time base phase shift control silicon controlled voltage regulator circuit.gif
- TTL driver thyristor circuit
- Thyristor circuit with sensitive trigger gate inductive load
- SCR automatic delay lighting switch
- SCR emergency power supply
