Incandescent lamp life extension electronic controller (1)
Source: InternetPublisher:小胖友 Keywords: Incandescent lamp electronic controller Updated: 2021/10/12
The working process of the circuit is: when the switch S is turned on
, since the voltage across the capacitor cannot change suddenly, the voltage across the capacitor C
is zero, and the thyristor is cut off without triggering voltage
. At this time, the current flowing through the bulb H is
the half-wave current rectified by the diode VD2. The bulb preheats and emits dim light, and the inrush
current is very small. If the capacitor C is charged by VDI and Rl,
after a delay of about 0.6s, when the voltage across C rises and reaches
the turn-on level of the thyristor vs, vs is turned on, and the bulb H is lit normally. Since
there is a 0.6s buffer delay time between the cold state and normal lighting of the bulb , the service life of the bulb is extended.
- Digital level display (CD40147, CD4511)
- A white light LED power outage emergency light
- Circuit diagram of game score display using 7-segment LED
- Laser detection and indicating device system circuit design
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- battery charging circuit
- One of the water full alarm circuits
- Resistor value selection circuit
- Chandelier brightness controller circuit using thyristor
- Bedside lamp controller circuit
- Incandescent lamp dimming circuit
- One light one switch lighting circuit
- One of the incandescent lamp dimming circuits using thyristors a
- Incandescent lamp life extension circuit 5
- Incandescent lamp life extension electronic controller (1)
- Incandescent lamp life extension switch circuit (1)
- 4-digit incandescent lamp display circuit
- Cold storage incandescent lamp voltage delay switch circuit
- Incandescent light bulb flasher
