Electric fan automatic control circuit
Source: InternetPublisher:常思一二 Keywords: Electric fan automatic control circuit Updated: 2020/06/05
Frame circuit) bistable circuit. Each bistable circuit controls the level of the output terminal by a single
key . When the circuit is instantly connected to the mains power, the mains power is stepped down by R13, cl,
full-wave rectification of VD, VD2, secondary voltage stabilization of ZD, ZDz, and then electronically filtered by VTs
to obtain a DC voltage of 8.5 V. Because of capacitance C. , C3, C, the voltage at both ends cannot
change suddenly, so the input terminals 1, 5, and 11 of the IC are low level, and the output terminals 2, 6, and 10 of the corresponding inverter
are high level, so each The output terminals 4, 8, and
12 of the bistable circuit are low level. Therefore, the bases of transistors VT,, VT2, and VT4 are at high level, and
VT,, VT,, and VT4 are cut off, and the base of VT3 is at low level , and VT3 is turned on. Because VT4 is cut off, there is no collector current
in VT3 . Therefore, the thyristors vs,, VS2, and
VS3 are cut off without trigger current , the lighting lamp L does not light up, and the motor M does not rotate. At the same time, the capacitors C2, C4 and C6 are charged through the resistor scale, R4 and Rg,
and can be charged to the power supply voltage of 8.5 V
in about 0.18.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- How to Build a Smart Knock Detection Door Lock Using Arduino
- What components and functions does the battery management system consist of?
- How to build a self-driving drone
- Mono LB1405 level indication circuit
- Telephone cipher circuit
- Smoke alarm circuit (1)
- Infrared light controlled toy tank circuit
- Stapler control circuit
- "Happy New Year" ring game console circuit
- Frequency-selective sonic remote control switch for electric fan a
- Connection diagram of speed-adjustable electric fan motor
- Stator circuit series resistance voltage reduction start automatic control circuit
- Exhaust fan automatic control circuit (2)
- Ventilation equipment automatic control circuit
- Infrared remote control multifunctional electric fan circuit
- Electric fan anti-shock safety device circuit
- Electric fan multi-purpose controller circuit
- Electric fan computer controller circuit
- Multifunctional electric fan controller circuit
