Universal remote control switch circuit
Source: InternetPublisher:三月小雨 Keywords: Switch circuit remote control switch BSP Updated: 2021/03/16
Circuit working principle: The circuit
consists of a power supply part, a sending part and a receiving part. The power supply is 5v DC voltage that is stepped down, rectified and stabilized by 7805 from the mains. The transmitting part (Figure a) is
a monostable circuit formed
around the NE555 timer ( IC
.). It uses two infrared light-emitting diodes (LEDs) to emit infrared light.
Use RP to set the output frequency of IC4 to 38 kHz. The transmitter part is powered by a 9V battery
The receiving part (Figure b) consists of infrared detector TSOP1738 (IRX.),
timer NE555 ( IC 2), counter CD4022 (LC3) and some discrete components
- Smart Farm Design Solution Based on LoRa
- Battery equalization system and control method thereof
- What components and functions does the battery management system consist of?
- Grain temperature measuring instrument circuit
- Homemade disinfectant circuit
- Electronic mousetrap circuit
- Micro infrared receiver module PIC-12043S circuit diagram
- Remote control fan speed regulator circuit
- HTS fire alarm
- Human body approaching safety protection warning circuit
- stuttering correction circuit
- Ultrasonic blind pathfinder circuit
- Proportional frequency discriminator circuit
- Diode square rate detection circuit
- Audio function generator composed of ICL8038
- Broadband high frequency power amplifier circuit
- common emitter amplifier circuit
- Power phase sequence display circuit
- Motorcycle flash light circuit
- Sine wave signal generator circuit
