Single-phase bridge rectifier circuit
Source: InternetPublisher:小胖友 Keywords: Bridge rectifier circuit diode Updated: 2020/08/18
working principle:
(1) u2 positive half cycle
u2 instantaneous polarity a(+), b(-). Diodes VD1 and VD3 are forward-biased and turned on, while VD2 and VD4 are reverse-biased and turned off. The conductive circuit is a→VD1→RL→VD3→b, and the voltage polarity on the load is positive up and negative down.
(2)u2 negative half cycle
u2 instantaneous polarity a(-), b(+). Diodes VD1 and VD3 are reverse-biased and cut off, VD2 and VD4 are forward-biased and conductive. The conductive circuit is b→VD2→RL→VD4→a. The polarity of the voltage on the load is also positive up and negative down.
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Driving circuit of switching power supply field effect tube
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Isolated two-wire current loop circuit (XTR101, ISO100)
- The constant current source composed of two transistors can drive high power
- Low cost and high performance LED constant current power supply
- Using CW34603 to form a circuit to change the polarity of the output power supply
- How to avoid electrical stress in chip design, do you know?
- Car voice-based mobile phone call reminder
- Automobile electronic fuel saver circuit diagram
- Diode Balanced Mixer Circuit
- Lighting light and dark conversion circuit
- 3 and 1/2 digit digital thermometer using diode as temperature sensor
- Double voltage rectifier circuit
- High frequency signal input switch circuit b
- Mosquito killer lamp circuit
- Incandescent lamp step-down circuit
