Multifunctional dimming light circuit using application-specific integrated circuit
Source: InternetPublisher:难得正经 Keywords: Application specific integrated circuit dimming lamp Updated: 2020/07/29
It is a multi-functional light lamp circuit made of HT7706 special integrated circuit
. It has
four different dimming functions: stepless, step dimming, delayed lights-off and cycle automatic lights-off.
HT7706 is
a multi-functional LED-specific integrated circuit
produced by Taiwan's Hetai Company
. It is
manufactured using CMOS technology and has
standard DIP-16 packages . The brief functions of the pins
are as follows. Pin ①zC is the
AC zero-crossing signal
input terminal. Pin ②(JSC,1
is the oscillation input terminal.
Pin ③OSC2 is the oscillation
output terminal. Pin ④TEST, test terminal, can be left floating in normal times. Pin ⑤Tl, test terminal, can
be left floating . Pin ⑥OUT, control signal At the output end, the control signal is added to the gate of the thyristor VTH through the capacitor c2
to control the conduction angle of the thyristor. Pin ⑦60/50 is the AC power frequency selection terminal. When the AC
frequency is 60HZ, this pin is left floating; When the AC frequency is 50Hz, this pin is connected to the negative terminal V of the power supply. Pin
⑧¨s is the negative terminal of the power supply. Pin ③PWR is the reset and clearing terminal. Pin ⑩BZ1 and pin ⑩B22 are buzzer
output terminals and can be connected externally. A piezoelectric ceramic buzzer piece B. Pin ⑩K1, keying input terminal l, low level trigger
is valid, external key switch SB1 is connected. When SB1 is pressed, the light changes from darkest to brightest (or from brightest to brightest) Dark) will
change steplessly. Release SB1 and the light brightness will be fixed. When the brightness is adjusted to the darkest or brightest, the light will
flash , and at the same time, the buzz output terminals BZ1 and t322 will output signals to cause the external buzz chip to B makes a "beep, beep"
sound, indicating that the brightness has withered to the extreme position. After turning on SB1, press SR1 again, the brightness will
change . Pin ⑩K2, keying input 2, low level The trigger is valid, and the external key switch SB2 is connected. Press
SB2 once, and the brightness changes by one gear, which is divided into 4 gears: off, low light, medium light and strong light. Pin @K3, keying input terminal
3, low level trigger is valid, external Press the button
to
turn on Terminal 4, low level trigger is valid, external key switch SB4 is connected. Press SL14 once, the light
will be on, and after 20min, the light will be off, and after 25min, the light will be on again... In this way, the light E will automatically light up and go out.
This mode is used for timing reminders. People, avoid working under the light for a long time, which is beneficial to eyesight protection or other purposes
. Pin ⑩V is the positive terminal of the power supply.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- DIY an electromagnetic levitation device
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Introduction to the internal structure of the Delta winding motor
- Using P110C to control 6 DC motors simultaneously
- Design and production of wireless multi-location control switch circuit
- Do-it-yourself trial production of phase failure protection device
- PIC microcontroller controlled remote anti-theft alarm circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Rural fish farming control circuit
- Egg heating control circuit
- Ringtone control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- sound control circuit
- SH-903 Holiday Lights ASIC
- SH-123 Holiday Lights ASIC
- YH01 lighting control application specific integrated circuit
- LS7232, S567, 5G7232 dimming control application specific integrated circuit
- Stepless dimming lamp circuit using application-specific integrated circuit
