Delayed lights-out pull switch circuit (1)
Source: InternetPublisher:已注销 Keywords: switching circuit power supply BSP Updated: 2020/02/10
It is a novel delayed light-off pull switch.
When turning on the light, it is the same as an ordinary pull switch. Pull the light to turn on.
When turning off the
light, it is different from the ordinary pull switch. When you need to turn off the light, pull the switch. The light will not go out immediately, but the light will turn on. The brightness
decreases and it takes a while to turn off. It is suitable for locking when going out at night or when going to bed.
When S is turned on on the stage, the positive half cycle of the alternating current passes through VD1 and VD1, causing the thyristor VT to pass through. At the same time, both ends of the capacitor C are also
filled with charges. At this time, the positive half cycle of the alternating current supplies power to bulb E through VT , and the negative half cycle
supplies power to bulb F through diode VD2, so bulb F is powered by umbrella voltage at this time. When setting the lamp, open the cover s and the capacitor c
will be discharged through the resistor R. This discharge current can maintain VT to continue to conduct, so there is still a positive half-cycle current flowing through the bulb E.䉉
Since s cuts off the VD2 power supply circuit of the negative 'l# cycle, the bulb is in a half-voltage power supply state, and E emits dim light.
About imln later, the capacitor C is discharged, and when the alternating current VT crosses zero, j is cut off, and the light E is completely extinguished.
- Build a Bluetooth-controlled wireless scoreboard
- Digital level display (CD40147, CD4511)
- Laser detection and indicating device system circuit design
- Design and production of a practical electronic counting device
- Infrared detection alarm
- Lighting lamp voltage stabilizing circuit (2)
- SC3071 touch step dimming light circuit
- Desk lamp dimming soft switch circuit
- WT8089 holiday lights ASIC
- 6-digit cathode fluorescent triode display circuit
- Set timing circuit when power is on
- stuttering correction circuit
- Ultrasonic blind pathfinder circuit
- Rice mill circuit
- Rural vegetable greenhouse lighting circuit
- Agricultural spraying and insecticide control circuit
- Domestic KD8041 integrated phase locked loop
- Junction field effect transistor mixer circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Power phase sequence display circuit
