Temperature range control circuit
Source: InternetPublisher:萌面大虾 Keywords: control circuit LED diode Updated: 2020/12/23
Circuit working principle: 220 V mains power is stepped down by transformer T, VD2-VD5 bridge
rectifier, C2 filtered and then supplied to the entire circuit. After the switch S is closed, since
the potential of point M is lower than 1/3 Vcc at this time, the 555 circuit is set, the output pin 3 is high level,
the relay K is closed, and the contact K-1 is turned on to control the heating. The circuit makes the temperature rise, and at the same time
the light- emitting diode LED indicates.
- timer call circuit
- Commonly used supporting equipment for general frequency converters
- LA5521D DC motor speed stabilizing circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Electric curtain circuit a Household appliance circuit
- Tube amplifier TDA1541 parallel circuit diagram
- LG Industrial iV5 inverter typical application circuit (2)
- Senlan BT12S type inverter one to two
- Use LB1405 LB1415 as volume meter application circuit
- Transformer AC contactor DC operation circuit b
- SG1524 driver LED circuit
- LED fluorescent lamp principle circuit diagram
- A simple DC LED driver circuit
- LT3755 driver LED application circuit diagram
- LED signal amplification circuit diagram
- LM3914 drives 20 LED light-emitting columns circuit diagram
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- Five-digit LED level indication driver integrated circuit typical circuit
- Coin guessing game circuit
- Household electric blanket power saving circuit
