Electronic Chameleon Circuit
Source: InternetPublisher:红水杯 Keywords: clock Updated: 2021/01/31
Circuit working principle: lC1 is a NE555 timer circuit , lC1 and peripheral components
form an oscillator. According to the data in the figure, its period is 3s, and the signal is output from pin 3. IC2
is the decimal counting distributor CD4017, which has three input terminals: clock terminal (CP),
reset terminal (R) and clock enable terminal (EN). When the EN terminal is low, the counter
transmits information under the action of the rising edge of the clock .
- One-digit display
- Audio level LED and digital dual display circuit
- Laser detection and indicating device system circuit design
- Electronic massage and acupuncture device circuit
- "OR" logic element configuration circuit
- Simple light-controlled street light circuit (7)
- Application circuit of CAT3606
- Economical and practical delay light circuit
- Temperature control alarm circuit
- Small current anti-theft alarm circuit
- Multi-output MEMS clock generator, do you understand it?
- 32.768kHz micropower clock oscillator circuit
- 32kHz transistor clock oscillator
- SAA1042 stepper motor control circuit
- Circuit diagram of ultrasonic range finder composed of ultrasonic ranging integrated circuit SB5027 with calendar clock
- 60HZ clock pulse generator circuit diagram
- Clock pulse edge shaping circuit
- N-phase clock source circuit diagram
- 60HZ clock output signal circuit diagram composed of 555
- The clock used to drive the flip-flop flash circuit
