Toshiba launches small dual MOSFETs for relay drivers
Source: InternetPublisher:张七岁 Keywords: Power supply regulated power supply driver Updated: 2020/01/23
Electronic Components & Storage Co., Ltd. today announced the launch of a new "SSM6N357R" product designed with a built-in diode between the drain and gate terminals. This device is suitable for driving inductive loads such as mechanical relays. Bulk shipping starts today.
The SSM6N357R integrates pull-down resistors, series resistors, and Zener diodes to help reduce parts count and save board space. In addition, because the product is a two-in-one package, the mounting area is reduced by 42% compared to the alternative of using two SSM3K357R (2.4 x 2.9 x 0.8 mm) single package products.
The SSM6N357R is packaged in an industry-standard TSOP6F grade package, has a low operating voltage of 3.0V, and is AEC-Q101 qualified, making it suitable for automotive and many other applications.
Application occasions
Relay and Solenoid Control for Automotive Applications
Relay and Solenoid Control for Industrial Applications
Office Equipment Clutch Control
Saves board space and reduces component count (enabling the integration of pull-down resistors, series resistors and Zener diodes.)
Low operating voltage of 3.0V
2-in-1 package
Passed AEC-Q101 certification
Main specifications
Equivalent Circuit
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Op amp power supply decoupling bypass measures
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Miniature polarity reversal power supply using MAX1721
- Adjustable voltage power socket
- MIC4680 constant current charger
- Mc34063 MP3 Switching Charger
- Power circuit of STR5412
- DC 12V to AC 100V inverter power supply circuit design
- Industrial product promotion and shopping guide DC power supply circuit
- 3v to 5v circuit diagram
- Power supply circuit with multiple outputs (MAX1902)
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Simple dual-channel variable DC power supply circuit
- Timing switch AC power circuit
- Telephone power circuit
- 5V uninterruptible power supply circuit
