Circuit design using LED to indicate current amplitude
Source: InternetPublisher:containsmachine Keywords: LED circuit design Updated: 2021/10/08
The luminous intensity of the LED in the picture is proportional to the load current . The circuit is designed to provide a very compact circuit to replace the meter on the 12V power line in some astronomical equipment. This equipment contains low-power heating elements (anti-exposure elements) whose operating conditions are not visible. However, when the heaters are switched on, the LEDs emit visible light, clearly indicating that they are connected and working.
Circuit analysis is very simple. The voltage across the 22 ohm resistor is the same as the voltage across RS ENSE. The current flowing through the 22 ohm resistor is the same as the current flowing through the LED. Therefore, for the parameter values given in the figure, the LED current is equal to 0.05/22 of the load current. When the load current changes from 200mA to 6.6A, the LED changes from weak light emission to full brightness (limited by the 680 ohm resistor).
If desired, another LED with a fixed resistor can be added for comparison. Alternatively, the histogram display can be obtained by constructing different examples of this circuit in which different resistors are used instead of the 22 ohm resistor and RS ENSE remains the same.
The op amp must have inputs and outputs with amplitudes up to the positive voltage rail and can withstand supply voltages of slightly more than 12V. TI's TLV2731 is ideal for meeting these requirements.
When the load current is 200mA, the LED emits weak light; when the load current increases to 6.6A, the LED emits the brightest light.
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Basic circuit description of adjustable voltage regulator LM317
- Constant current LED lamp driver circuit with soft start and anti-shock
- Switching power supply circuit composition and function introduction of each part
- Low cost and high performance LED constant current power supply
- Adjustable regulated power supply with current limiting protection
- Circuit diagram explanation: simple switching power supply circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- Do you know about the YTSwitch-6 LED driver IC with high efficiency and extremely low standby power?
- What sensors does the phone have?
- MAX684 charge pump driving white LED circuit diagram
- MAX8631X driving white LED circuit diagram
- Circuit using NCP1216 to drive LED
- S8050 low-cost high-performance LED constant current power supply circuit diagram
- Three-color marquee circuit diagram
- Machine-made tile humidity measurement circuit
- Transformer overtemperature alarm circuit
- IS0100 functional schematic diagram
