LTC5551 base station receiver circuit diagram
Source: InternetPublisher:风向双子座 Keywords: Power supply other power circuits Updated: 2021/02/22
The LTC®5551 is a 2.5V to 3.6V mixer optimized for RF downconversion mixer applications requiring very high dynamic range. The LTC5551 covers the 300MHz to 3.5GHz RF frequency range and the 200MHz to 3.5GHz LO frequency range. The LTC5551 features very high IIP3 and P1dB and low power consumption. A typical application for this device is in base station receivers covering the frequency range of 700MHz to 2.7GHz. The RF input is capable of matching a wide range of frequencies, and the IF can be used up to 1GHz.
![LTC5551 base station receiver circuit diagram](http://www.eeworld.com.cn/circuit/upload/90d896fb3bfc22424cb1f0911381bcd4/fa11e88dd1ef02df2c3f672481827158.jpg)
- Analysis of the working principle of switching regulator
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- A very convenient small power supply circuit to share
- In-depth analysis of DC-AC converter inverter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Simple and practical LED lamp driving circuit
- LED Driver ZD1680
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
