High power DC/DC complete circuit diagram controlled by LTC3722-1
Source: InternetPublisher:aerobotics Keywords: High power circuit diagram LTC Updated: 2021/12/06
LTC 3722 - 1/2 phase-shifted PWM controller provides all the control functions of a full-bridge zero-voltage switching (ZVS) for high-efficiency conversion. The adaptive mode ZVS circuit delay function provides the turn-on signal to each MOSFET to overcome the deviation of each component. The manual delay setting method allows the secondary side synchronous rectification drive signal to directly achieve turn-on delay.
The LTC3722-1/2 also features adjustable synchronous rectification timing for optimal efficiency. After UVL0 adjusts the input voltage and adds it, the system has accurate turn-on and turn-off voltages. LTC3722-1 is a peak current control method that can accurately adjust slope compensation and leading edge clipping. LTC3722-2 adopts voltage type control and has various voltage feedforward functions.
In addition, both ICs have extremely low starting current and operating current, have complete protection functions, and adopt a 24PIN surface-mounted appearance structure.
The complete circuit of high-power DC/DC controlled by LTC3722-1 is shown in Figure 1:
Figure 1 High-power DC/DC complete circuit controlled by LTC 3722-1
- How about the boost converter TPS61299?
- Energy-saving motorcycle rectifier regulator
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Op amp power supply decoupling bypass measures
- A simple positive and negative power supply circuit
- A small and easy-to-make fast charger
- A novel and practical DC low voltage stabilized power supply
- Car power 1.5V-12V six-speed converter
- Design of electric vehicle charger
- MAX1811 Lithium Battery Charger Production
- Multiple sets of colorful light chain circuits that flash in cycles Part 5
- Pre-frequency crossover power amplifier
- Super fool high power amplifier module 01
- Single LTC power circuit
- Simple fade-in and fade-out switch circuit (2)
- High efficiency nickel-cadmium battery charger IC (LTC1148) circuit
- High power time controller circuit
- LTC1159 application circuit diagram 1
- Basic application circuit diagram of LTC1159
- Micropower LTC221 Quad CMOS Analog Switch with Data Latch
