Adjustable regulated power supply circuit diagram with low output voltage
Source: InternetPublisher:睡不醒的小壮 Keywords: Adjustable regulated power supply power supply circuit diagram regulated power supply circuit output voltage Updated: 2020/02/09
This circuit is suitable for application under the following conditions: the minimum output voltage Uamin>0.5V. The output voltage Ua is the sum of Ub and Ur, where Ur is the voltage stabilization value of the integrated voltage stabilizing circuit.
The formula for adjusting the output voltage is Ua=Ur.R2/4. The current in the adjusting branches R4 and R5 is about 1mA (when Ua≈0.5V). The resistor R should be selected so that Ur1 has a value of 1V when I1 is minimum in the equation I1=Ir+I2 to ensure that the operational amplifier has sufficient negative voltage. The selection of R2 and R3 values depends on the value of R4+R5, which should allow a current of about 1mA to flow, that is, R2+R3=Ur/1mA.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Benefits of Wide Bandgap Technology for Power Converters
- Practical and convenient fax machine power supply control circuit
- Introduction and principle analysis of switching regulated power supply
- Visible laser digital control modulation driver
- Use pulse width modulation to get a precise output voltage
- Detailed explanation of 5v charger circuit diagram
- A simple positive and negative power supply circuit
- Dynamic power supply for power amplifier controlled by thyristor
- 3~15V 10A adjustable voltage regulated power supply
- Excellent performance household inverter power supply circuit
- 3v to 5v circuit diagram
- EPSON PHOTO 830U printer power circuit
- Output 85 to 145V adjustable regulated power supply circuit
- Simple bipolar adjustable regulated power supply circuit
- Output adjustable voltage stabilized power supply circuit
- DIY power supply with current limiting gear and adjustable voltage
- High-precision adjustable voltage stabilized power supply circuit diagram
- Use 7805 to form an adjustable regulated power supply
