Rectifier module circuit diagram composed of DZW75-48/50 (50II) type
Source: InternetPublisher:张七岁 Keywords: Rectifier module module circuit circuit diagram Updated: 2021/07/17
The technical performance of the DZW75 series switching rectifier module is as follows: (1) Voltage stabilization accuracy: <±0.5%: (2) Noise voltage: ① Telephone scale noise voltage < 2mV ② Peak-to-peak noise voltage < 200mV ③ Broadband noise < 100mV (3.4kHz~150kHz) <20mV (0.15MHz~30MHz) ④ Discrete noise <5mV (3.4kHz~150kHz) <3mV (150kHz~200kHz) <2mV (200kHz~500kHz) <LMV (0.5MHZ~30MHZ) (3) Efficiency >85%; (4) Power factor: >85% (99% for DZW75-48/50II); (5) Load sharing: ≤±0.5%: (6) With overvoltage, undervoltage and overcurrent jumps It has machine protection and soft-start functions; (7) It has remote control, remote signaling, and telemetry interfaces; (8) It has autonomous working mode/non-autonomous working mode.
ck="window.open(this.src)" alt="Click to see larger image" />
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic circuit description of adjustable voltage regulator LM317
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Adjustable regulated power supply with current limiting protection
- Car power 1.5V-12V six-speed converter
- Adjustable voltage regulated power supply circuit
- The production of adjustable voltage-stabilized power supply composed of LM317
- A low-cost, high-reliability battery charger for electric vehicles
- LM317T voltage regulation adjustable circuit diagram explanation
- How to Select Modular EMI Filters for AC-DC Converters
- Excellent performance household inverter power supply circuit
- Power circuit b composed of intelligent thyristor modules
- Power supply circuit with multiple outputs (MAX1902)
- Transistor stabilized current power supply circuit 2
- Timing switch AC power circuit
- Household emergency power circuit 02
- ±15V active servo power circuit
- Pressure sensor module circuit diagram
- Homemade three-terminal voltage stabilizing module circuit diagram
- Double-arm rectifier module single-phase full-wave rectifier circuit
