AC electronic voltage regulator using TL431
Source: InternetPublisher:张三叔 Keywords: tl431 integrated power supply AC electronic voltage regulator Updated: 2021/03/10
TL431 is an adjustable precision voltage regulator with low noise and continuously adjustable output voltage (25~36V). The output dynamic resistance is small and the current is large. Therefore, it has been widely used in electronic circuits.
Applying TL431 to an AC voltage regulator can simplify the circuit structure and improve circuit performance. The AC electronic voltage regulator designed in this article automatically adjusts the output voltage to 220V+-7% when the mains voltage changes within the range of 158~270V. When the mains voltage is lower than 158V or higher than 270V, it can automatically cut off the power supply. Therefore, it has under-voltage and over-voltage protection functions.
![AC electronic voltage regulator using TL431](http://www.eeworld.com.cn/circuit/upload/0c1126cf9d455c96e5b88239846bf00f/2f7419397551aa59604dbbdf89e5fb26.png)
The figure below is the circuit diagram of an AC electronic voltage regulator. In the figure, R1 to R5 are 10k ohms, RP1~RP5 are 10k ohm potentiometers, A1~A5 are TL431, V1~V4 are IN4001, C is 4700uF/50V, and K1~K5 are JQX-14F (DC12V). After the mains power is filtered by the autotransformer T, V1~V4 bridge rectifier and capacitor C, it is used for voltage sampling by the detection circuit. The +12V power supply is obtained by 7812 stabilizing the voltage filtered by capacitor C (note: omitted in the figure). Taps 1 and 3 of the transformer are used as fixed mains input, and the voltage at both ends of the capacitor C also changes within the range of 158~270V. When the potentiometer changes, when the adjustable terminal voltage of RP1~RP4 exceeds 2.5V, A1~A4 will be turned on in sequence, causing relays K1~K4 to be closed in turn, thus changing the tap of the output end and the voltage regulator from 5->2 to achieve the purpose of automatic voltage regulation.
When the mains input is from 158~180V, A1 is turned on, and taps 1 and 5 output 220V±7%; when the mains input is from 180~205V, A1.A2 is turned on, and tap 1.4 outputs 220V±7%; When the mains input is from 205 to 235V, A1, A2 and A3 are turned on, and the 1.3 tap outputs 220V+-7% directly; when the mains input is from 235 to 270V, A1, A2, A3 and A4. On, the 1.2 tap outputs 220Vt7%; when the mains input is lower than 150V, A1 does not conduct, K1 releases the closed contact, cuts off the output power supply circuit, and plays the role of under-voltage protection; when the mains input is higher than 270V , A6 conducts, K5 pulls in, cuts off the output power supply circuit, and plays the role of overvoltage protection.
Since the voltage regulator introduced in this article uses TL431, it is easy to adjust the voltage regulating range and overvoltage and undervoltage protection values of the voltage regulator by changing the position of the adjustable ends of the potentiometers RP1~RP5.
- How to Make a Soft Latch Circuit
- Introduction and principle analysis of switching regulated power supply
- Basic connection circuit of signal and power supply composed of ISOll3
- LED rechargeable flashlight circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A simple positive and negative power supply circuit
- 0.7~24V continuously adjustable current limiting power supply
- UC3842 Electric Vehicle Charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Homemade Electric Bike Fast Charger
- Basic application circuit diagram of TL431
- Excellent performance household inverter power supply circuit
- DC 12V to AC 100V inverter power supply circuit design
- Power circuit a composed of intelligent thyristor modules
- Voltage stabilization control circuit in power circuit
- Power supply circuit with multiple outputs (MAX1902)
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Adjustable voltage stabilized power supply composed of MC7805 and TL431
- Overvoltage protection circuit diagram using TL431 precision reference source, etc.
- Parallel regulated power supply circuit diagram using TL431
