CD4541 cadmium nickel battery automatic charging circuit diagram
Source: InternetPublisher:李商隐身 Keywords: Charging circuit circuit diagram automatic charging battery Updated: 2020/08/05
As shown in the figure is an automatic charger circuit for nickel-cadmium batteries composed of CD 4001/CD4541.
This circuit is specially designed for charging No. 5 and No. 7 cadmium nickel batteries. It has the characteristics of automatic charging and constant current charging. The circuit is shown in the figure. The circuit starts working after the power is turned on, and the internal counter counts the oscillator. When the count is full, the output level of pin 8 of IC1 flips and stops counting. If the M terminal of pin 10 is connected to high level, pin 8 will flip after the count is full, and then count again, and then flip again after the count is full, and so on.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- Fabrication of multi-cell lithium battery charging circuit
- Simple and practical LED lamp driving circuit
- Principles and precautions of active discharge circuit
- How to use SBR to improve power conversion efficiency
- A small and easy-to-make fast charger
- Homemade low-power UPS
- CNC regulated power supply production
- 0.7~24V continuously adjustable current limiting power supply
- Single and multi-cell charging circuits
- New fast charging I constant current source charging circuit
- New fast charging I charging circuit with discharge
- RC charging circuit
- Simple programmable charging circuit
- Wind turbine battery charging circuit
- Charging circuit with reverse connection display
- Pulsating constant current charging circuit diagram
- Switching constant current charging circuit diagram
- Charging circuit diagram with power generation circuit using U2402B
