Automotive voltage regulator circuit diagram composed of LM723
Source: InternetPublisher:李商隐身 Keywords: Circuit diagram voltage regulator LM723 Updated: 2021/12/29
The picture shows a fixed circuit automobile voltage regulator circuit composed of LM723 . It can replace the electromechanical charging voltage regulator composed of a generator system in the automobile, and its performance is better than the latter. It prevents undercharging or overcharging of 12V lead-acid batteries, thereby extending battery life. In the circuit, LM723 is used as a switching regulator to control the excitation current of the generator. The resistance of R2 needs to be adjusted so that the charging voltage can be maintained at the full voltage of a standard car battery of 13.8V. Q1 is a 2N2063A (SK3009), 10A, PNP transistor.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Practical and convenient fax machine power supply control circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- LED Driver ZD1680
- LED rechargeable flashlight circuit diagram
- Miniature polarity reversal power supply using MAX1721
- 0.7~24V continuously adjustable current limiting power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Car Audio Power Supply
- Typical Reference Voltage and Power Supply Circuits
- Three-way DC-DC converter circuit
- Simple dual-channel variable DC power supply circuit
- led drive power circuit
- Power circuit for home appliance repair
- Common power circuits and applications 07
- Inverter power circuit
- ±5V, ±12V power circuit A
- CTX-C2 dual-band high-resolution color display power circuit
- LM723 high precision regulated power supply
