LED drive circuit using low-frequency transformer and resistor current-limiting half-wave or full-wave rectification
Source: InternetPublisher:fish001 Keywords: transformer rectifier low frequency Updated: 2021/02/06
The advantages of this circuit are: simple circuit and low cost. The disadvantages are: large size, voltage drive mode, LED brightness will change with changes in supply voltage; unable to provide constant current output; large surge current. The circuit structure of this LED driving power supply is very simple, requiring only a low-frequency transformer , rectifier, filter capacitor, and a variable resistor for adjusting brightness . The number of LEDs in series is mainly determined by the turns ratio of the transformer. Once the turns ratio of the transformer is fixed, it is difficult to change the number of LEDs to obtain the same brightness of 9.
- IRS2530D electronic ballast circuit diagram
- LED Signage with RS232 Port Operation Guide
- Laser detection and indicating device system circuit design
- Simple electronic doorbell circuit
- Electronic music dimming desk lamp circuit
- Application circuit of CAT3606
- Automotive LED driver circuit diagram using LT3486
- Frost alarm circuit
- Electronic rapid starter for fluorescent lamps
- Night target display circuit diagram
- Car battery charging circuit diagram
- Neon light circuit
- Single wire AM radio circuit
- Commonly used low pass filter circuit a
- DC servo constant current power amplifier 02
- DC servo constant current power amplifier 01
- Application of TDA1514
- Variable frequency low frequency LC oscillator circuit
- Low frequency multiple waveform generator circuit diagram
- 6W low frequency integrated bridge amplifier circuit diagram
