Practical circuit based on LT3468 dual output boost LED driver
Source: InternetPublisher:newrudeman Keywords: LED driver boost type practical circuit Updated: 2020/03/20
This circuit is a practical circuit based on the LT3486 dual-output boost LED driver . It drives two strings of LEDs with a constant current of 100mA, and the LED voltage is up to 36V. This boost converter uses a small voltage sense resistor in series with the LED string and PWM dimming MOSFET and has high efficiency. The dual-channel LED driver drives two LED strings of 20 LEDs over a battery voltage range of 9 to 16V while keeping the maximum switching voltage below the IC's 42V rating.
- Experiment on realizing photoelectric alarm using photosensitive devices
- Design and production of digital number answering machine
- Low illumination amplifier circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Lighting audio control circuit
- Fluorescent lamp electronic ballast circuit 11
- Fluorescent lamp dimming circuit composed of thyristors
- SH-803R holiday lights ASIC
- Small current anti-theft alarm circuit
- Touch lighting switch circuit three
- Equalizer practical circuit
- Improved monostable practical circuit b
- Bistable flip-flop practical circuit b
- LM3875 practical circuit-single power supply
- LED driver CAT3606 application circuit diagram
- Application circuit of LT3468 dual output boost LED driver
- Typical application circuit of high power LED driver TPS92310 block diagram
- Boost DC, DC converter circuit diagram
- Adjustable bipolar boost regulated power supply circuit diagram
- MAX813L and MCS-51 microcontroller reset practical circuit
