50W white LED headlight driver circuit diagram based on LT3755
Source: InternetPublisher:太白金星 Keywords: White LED driver circuit diagram LT3755 WIDTH Updated: 2021/03/16
The LT3755 senses output current on the high-side side of the LED string. High-side current sensing is the most flexible solution for driving LEDs. The PWM input provides a dimming ratio of up to 3000:1, while the CTRL input provides additional analog dimming. Light ability. The LT3755 is available in 16-pin (3mm × 3mm) QFN and MS0P packages. The main technical characteristics of LT3755
are as follows:
(1) Wide input voltage range (4.5~40V).
(2) Output voltage up to 75V.
(3) Fixed current and constant voltage regulation.
(4) 100mV high-end current detection.
(5) Boost, buck, buck-boost, SEPIC or flyback topologies can be used to drive LEDs.
(6) It has programmable under-voltage lockout protection function with LED open circuit and hysteresis.
(7) Open LED status pin.
(8) PWM disconnect switch driver.
(9) The CTRL pin provides analog dimming function.
(10) Low shutdown current: <1uA.
- One-digit display
- LED acceleration and deceleration motion display composed of CD4017
- Delayed gradual lighting with protection function
- LED Flasher circuit using 2 transistors for LED switching
- Design and production of rain control and light control timing controller based on P87LPC764
- Mains undervoltage and overvoltage protection circuit 2
- Digital display multi-function thermometer circuit
- Shock resistant soft start constant current LED lighting circuit
- Electronic rapid starter for fluorescent lamps
- Bedside lamp controller circuit
- AN7161N power amplifier circuit diagram
- AC 220V to DC 600V switching power supply circuit diagram
- EW-8W electronic ballast circuit diagram
- Crystal oscillator 80mW FM transmitter production circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Constant voltage current limiting charger circuit
- Positive temperature sensor and coefficient resistor circuit diagram
- Circuit diagram of using NCP3065/NCP3066 to drive LED
- Multi-waveform signal generator circuit diagram
- LT3755 driver LED application circuit
