Stabilized dual power supply circuit
Source: InternetPublisher:司马缸砸光 Keywords: Transformer power supply stabilized power supply Updated: 2020/06/17
describe
The circuit given here is a specification, providing dual supply power of +12V and -12V from an AC source. A power supply like this is a very important tool on an electronics hobbyist's workbench. Transformer T1 drops the AC supply voltage and diodes D1, D2, step rectification work, D3 and D4. Capacitors C1 and C2 work as filtering.C3, C4, C7and C8 are the decoupling capacitors. ICs 7812 and 7912 are used for voltage regulation purposes where the former is a positive 12V regulator and the later is a negative 12V regulator. 7812 outputs +12 V and 7912, will - 12V.
Circuit diagram and parts list
Precautions
Good quality printed circuit board assembled circuit.
Transformer T1 can be a 230V main; 15-0-15 V, 1A secondary step-down transformer.
Fuse F1 can be a 500mA fuse.
Capacitors C1, C2, C5 and C6 must be rated at least 50V.
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- Fabrication of multi-cell lithium battery charging circuit
- LNK304 non-isolated LED light string driver circuit
- Charging control circuit made by solar energy
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- IF amplification and detection circuit in AM radio
- Single wire AM radio circuit
- Lightning protection wiring of oil switch on pole a
- Y, y connected transformer lightning protection wiring
- Simple buzzer circuit three
- Mingdan 2A3 and its applications 02
- 48V/50A rectifier module DC/DC main circuit
- Switching power supply drive transformer EE-18
- Transformer output power amplifier circuit diagram
- 30W feedback transformer switching power supply circuit diagram
