Photoelectric switch circuit diagram on AC power grid
Source: InternetPublisher:ohahaha Keywords: Photoelectric switch switch circuit diagram power grid Updated: 2020/12/06
As shown in the figure, the circuit will only operate when the light intensity is above 700lx. At this time, the phototransistor BPX25 and the transistor BFY52 trigger the current to the thyristor BTY91/800R. When there is light on the phototransistor, the trigger pulse always appears about 6 degrees after the starting point of each positive half cycle, and the arithmetic mean of the DC half-wave current flowing through the load is at most 16A.
The voltage regulator tube BZY88/C5 and the transistor T1 and their connecting resistance are 390 ohms, which are used to limit the voltage of the trigger circuit to no more than 6V. The diode BYX45/800R is used to block the negative half-cycle grid voltage, the resistor 33 ohms and the capacitor 0.1uF are used to protect the thyristor and prevent over-voltage.
ck="window.open(this.src)" alt="Click to see larger image" />
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Design and selection of electric control valve system drive
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Design of an autonomous plant watering system using ATtiny85
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- DIY an electromagnetic levitation device
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Design and production of wireless multi-location control switch circuit
- Design and production of no-load automatic power-off device for household power supply
- Ultra-short wave item left behind reminder alarm
- Static switch circuit diagram of integrated trigger tdal024
- Hall effect switch circuit diagram
- Touch switch circuit diagram D
- Infrared receiving and decoding remote control switch circuit diagram
- Light controlled switch circuit diagram of bidirectional thyristor
- Automatic cycle switch circuit diagram
- Photoresistor controlled street light switch circuit diagram
- Temperature controlled silicon controlled zero crossing switch circuit diagram
- Photoelectric isolation fast switch circuit diagram
- Multifunctional leakage protection switch circuit diagram
