Double-channel three-phase power supply automatic switching circuit circuit diagram
Source: InternetPublisher:太白金星 Keywords: Three-phase power supply circuit diagram wiring time relay Updated: 2021/01/06
As shown in the figure is a dual-channel three-phase power supply automatic switching line circuit. When using electricity, the knife switches 1HK and 2HK can be closed at the same time, and the 1C normally closed contact disconnects the power supply of the SJ time relay . Supply power to the load. When the power supply A fails for some reason, the 1C contactor is released. At this time, the IC is normally closed, and the power supply on the time relay SJ line diagram is turned on. After the time relay is delayed for a few seconds, the SJ delay normally open point is closed, and 2C is obtained. Electrically attracted and self-locking. Due to the pull-in of 2C, its normally closed point on the one hand disconnects the power supply of the delay relay line diagram, and on the other hand double-disconnects the power circuit of the 1C coil, so that power supply A stops supplying power and ensures that power supply B supplies normal power. If power supply B has been working for a period of time and then has a power outage, the normally closed point of 2C will automatically turn on the power supply of coil 1C to switch to power supply A.
The contactor should be selected according to the load size; the time relay can be an AC time relay of 0~60S .
ck="window.open(this.src)" alt="Click to see larger image" />
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Low cost and high performance LED constant current power supply
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Design of electric vehicle charger
- Three Phase Power Transformer Current Monitor
- Transistor time relay circuit 2
- Forward and reverse adjustable speed control circuit with integrated braking function
- Frequency sensitive rheostat automatic forward and reverse starting circuit
- JSKJ type transistor time relay circuit (DC)
- JS13 type transistor time relay circuit
- Time relay circuit diagram
- The most practical basic diagram circuit 25 - pulse charging time relay circuit
- The most practical basic diagram circuit 10 - dual-channel three-phase power supply automatic switching circuit
- The most practical basic diagram circuit 09 - three-phase power indication and protection circuit
