Door status detection circuit diagram
Source: InternetPublisher:刘德华河北分华 Keywords: Test and measurement circuit door status detection circuit diagram Updated: 2021/08/08
The picture above shows a bus door status detection circuit. The circuit is mainly composed of three Hall sensors and is suitable for indicating the door status in various cars. Three Hall sensors are installed on the door frame of the bus door, and magnets are installed at appropriate positions on the door. When the door is open, the magnet is farther away from the Hall sensor so that its output terminal outputs a high level. If any one of the three Hall sensors detects that the door is not closed or locked, the NOR gate outputs low level and the red indicator light turns on; if all three sensors output high level, the NAND gate outputs high level and green The indicator light is on, showing the current status of the door in real time.
- How to Measure Turbidity of Liquids Using Arduino
- Multimeter with small capacitor test circuit
- New function added to MF-47D multimeter - infrared remote control detection
- Make a Economical and Practical Rectifier Voltmeter
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Using NE555 to make diode and triode detector
- Making an Induction Electroscope Using CD4069
- Simple and easy to make zero degree detector
- Low resistance connection tester circuit diagram sharing
- DC power meter
- Capacitive proximity sensing detection circuit
- Overcurrent detection circuit
- Copier paper tail detection circuit composed of photoresistor sensor
- Three-phase AC power supply phase sequence detection circuit
- Transistor multiple "1" detection circuit
- Simple phase detection circuit
- A5348 smoke alarm detection circuit - block diagram
- and light detection circuit
- Photodiode pollution gas detection circuit
- Gas concentration detection circuit
