SVG principle diagram
Source: InternetPublisher:傻阿乐 Keywords: svg reactive power compensation comprehensive power supply Updated: 2020/03/29
SVG is the abbreviation of Static Var Generator and is the representative of the latest technology in the field of reactive power compensation today. SVG is connected in parallel to the power grid and is equivalent to a variable reactive current source. Its reactive current can be flexibly controlled and automatically compensates for the reactive power required by the system. Because of its extremely fast response speed, it is also called a Static Synchronous Compensator (STATCOM for short).
![SVG principle diagram](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/a9cc8d660fd8d520e2abd15400975b1a.jpg)
The technical basis of SVG is Voltage Sourced Converter (VSC). Its basic principle is to use high-power power electronic devices that can be turned off, such as IGBT, to form a self-commutated bridge circuit. The DC voltage is inverted into AC, and then connected in parallel to the power grid through a reactor to appropriately adjust the amplitude and phase of the output voltage on the AC side of the bridge circuit. Or directly controlling the AC side current can make the circuit absorb or emit reactive current that meets the requirements to achieve the purpose of dynamic reactive power compensation.
![SVG principle diagram](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/75af83dabb5974534c9ab3c863ce46d7.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Current/voltage conversion circuit using current converter
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Constant current charger using light emitting diode as voltage regulator
- Homemade Electric Bike Fast Charger
- Power supply circuit design optimized for digital light projectors
- KGDS type single-phase low temperature iron plated power supply circuit
- Timing switch AC power circuit
- Remote control TV doorbell power circuit
- DC power supply circuit for semiconductor radio
- Practical neon light power circuit
- Common power circuits and applications 03
- Always ready power circuit
- ±5V, ±12V power circuit B
- ±5V, ±12V power circuit A
