60Hz time base generator composed of MM5369
Source: InternetPublisher:抄写员 Keywords: timer wireless communication mm5369 time base generator Updated: 2021/11/11
As shown in the figure is the 60Hz time base generating circuit. In many occasions, 60Hz has become a basic reference frequency, such as electronic clocks, timers, controllers, etc., all designed to use 60Hz as their working reference signal. Therefore, an independent 60Hz signal source is often needed for various portable or battery-powered circuits and for testing and development purposes. This circuit is composed of the integrated circuit MM5369 time base generator. This device requires an external crystal, which is cut according to the standard 3.579545MHz color TV "color sync signal" frequency. The output of the circuit is at two frequencies: 60Hz and 3.58MHz. The circuit can output the correct frequency with the help of a 5-50pF variable capacitor. This frequency can be monitored with a frequency meter or similar instrument.
![60Hz time base generator composed of MM5369](http://www.eeworld.com.cn/circuit/upload/cdbdb8bfd5819dcf15f66e8c3deef163/684b0f9a06bfcb229d1df5e79388706f.jpg)
- How to Build a Simple FM Radio Receiver on a Breadboard
- DIY a network router
- Homemade modified machine with 4 LNB inputs and audio and video outputs
- MGCT02 I/Q TDMA/AMPS l900/900 MHz Dual-Band Dual-Mode Transmitter
- RF2942 I/Q 915 MHz Transmitter
- RXM-921/916/903/868/433-ES Series Receiver Modules
- QMR1/QMR2 AM/FM 868/433.92 MHz Receiver Module
- GPS RF front-end circuit composed of MX2740
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- MICRF500 FSK 1000~700 MHz Transceiver
- Square wave generation circuit
- Micro wireless walkie-talkie circuit diagram
- FM radio circuit diagram using FET
- Continuous timing circuit diagram for delayed monostable multivibrator
- TDA5142T schematic block diagram and typical applications
- Precision countdown timer
- Photosensitive timer
- Precision timer composed of LM567 and MP1826
- 2 minutes to 4 hours timer
- 9V charger with digital circuit timer
