Application circuit diagram of 1880MHz internal collector bias amplifier composed of RF2324
Source: InternetPublisher:抄写员 Keywords: Power supply other power circuits Updated: 2021/09/26
Shown in the figure is an 1880MHz internal collector bias amplifier application circuit composed of RF2324. The radio frequency signal (RF) is input through pin 3, and is output through pin 7 after being amplified by the preamplifier and final power amplifier. Pin 3 is directly coupled to the internal amplifier, so a 10pF DC coupling capacitor is added, and the matching impedance is 50Ω when operating at 1880MHz. Pin 7 is the output end of the open collector, which can be connected to the power supply Vcc through a choke or matching inductor. The typical matching impedance of this pin is 50Ω. An external output matching network is connected to match the amplifier output impedance to obtain maximum output power and efficiency. . Pin 1 is the power reduction control terminal. When VPD=2.8V±0.1V (typical IPD value is 8.5mA) the circuit works; when VPD<0.9V the circuit turns off. VPD requires an additional RF bypass circuit.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Energy-saving motorcycle rectifier regulator
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Basic connection circuit of signal and power supply composed of ISOll3
- The constant current source composed of two transistors can drive high power
- Low cost and high performance LED constant current power supply
- Using CW34603 to form a circuit to change the polarity of the output power supply
- LM317 regulated power supply
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
