Head preamplifier circuit designed by OPA37
Source: InternetPublisher:司马缸砸光 Keywords: Power supply other power circuits Updated: 2021/05/21
This circuit is a common tape recorder head amplifier circuit in the 1990s. It uses a head pre-op amplifier composed of ultra-low noise precision operational amplifier OPA37. The circuit can provide standard NAB equalization. Its voltage amplification factor is 50dB at 1kHz. The audio input signal is picked up by the magnetic head device and sent to the non-inverting input end of the OPA37. This connection method makes the op amp have a high input impedance, that is, pin 3 of the OPA37 to the ground can be approximately open circuit, and RL and CL in the circuit form the load of the magnetic head. impedance. The value recommended by the magnetic head manufacturer should be used. The resistive and capacitive components in the circuit should use high-quality metal film resistors and organic synthetic film capacitors.
- The basic principles of power supply design. What are the key components of a power supply?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to Make a Soft Latch Circuit
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Visible laser digital control modulation driver
- MIC4680 constant current charger
- Adjustable voltage regulated power supply circuit
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
