Simple transistor relay delay pull-in circuit diagram
Source: InternetPublisher:笑流年 Keywords: Transistors power supplies and other power circuits Updated: 2021/04/19
The figure below is a relay delay pull-in circuit composed of transistors. When the power is first turned on, the voltage on the 16μF capacitor is zero, both transistors are cut off, and the relay does not operate. As the 16μF capacitor is charged, after a period of time, the voltage on it reaches a high level, both transistors are turned on, and the relay is delayed and closed. The delay time can reach 60s. The delay time can be adjusted through the 10MΩ resistor.
![Simple transistor relay delay pull-in circuit diagram](http://www.eeworld.com.cn/circuit/upload/bf8c3a716e2b88f93e6a770d7495c9db/ea5ec93c84861b639a77fd729d79ae69.jpg)
- Single-power supply circuit for ISO122P/ISO124
- Driving circuit that controls LED brightness using PWM signal
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Constant current LED lamp driver circuit with soft start and anti-shock
- Parallel DC regulated power supply circuit diagram
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- A low-cost, high-reliability battery charger for electric vehicles
- Circuit diagram explanation: simple switching power supply circuit diagram
- 3V-5V level conversion circuit diagram
- Improved connection method of triode switch circuit circuit diagram
- Homemade C3355 transistor 1km FM transmitter circuit diagram
- One of the battery charge status indication circuits
- Improved multivibrator circuitb
- Soft start regulated power supply circuit three
- 95V, 100mA regulated power supply circuit
- Unijunction transistor wide pulse trigger circuit
- Cotton humidity detection circuit
