STM32F1 and minimum system circuit diagram
Source: InternetPublisher:同住地球村 Keywords: Power supply other power circuits Updated: 2021/09/01
Clock, reset and power management:
2.0~3.6V power supply and IO voltage
Power-on reset, brownout reset and programmable voltage monitoring
Powerful clock system
-4~16M external high-speed crystal oscillator. The author used the Atomic Mini version STM32F103RCT6 when studying. The external crystal oscillator used is 8MHz.
-Internal 8MHz high-speed RC oscillator (used when the external high-speed crystal oscillator is broken, automatically). This function will also be mentioned in my other blog, and is generally not used.
- Internal 40KHz low speed RC oscillator for watchdog clock
-Internal phase-locked loop (PLL, frequency multiplication). Generally, the system clock is obtained by multiplying the external or internal high-speed clock by PLL (the oscillation can be multiplied from 8M to 72M)
-External low-speed 32.768K crystal oscillator, mainly used as RTC clock source
Low power consumption
Three low-power modes: sleep, stop and standby
Battery available to power RTC and backup registers
AD
3 12-bit AD, 21 external measurement channels
DA
2 12-bit DA
DMA
12 DMA channels (7+5=12; 7-channel DMA1, 5-channel DMA2)
Supported peripherals: timers, ADC, DAC, SDIO, I2S, SPI, I2C, and USART
timer
4 general timers
2 basic timers
2 advanced timers
1 system timer
2 watchdog timers
Communication interface: up to 13 communication interfaces
2 I2C interfaces
5 serial ports (3 USART and 2 UART)
3 SPI interfaces
1 CAN2.0
1 USB FS
1 SDIO
internal structure
![STM32F1 and minimum system circuit diagram](http://www.eeworld.com.cn/circuit/upload/dda73ac31da3e7cca4f82e5788faba5e/b9fb483c4de909d5d6911855f56900a2.jpg)
smallest system
powered by
Powered by Vcc=3.3V, it can be converted by AMS-1117
reset
![STM32F1 and minimum system circuit diagram](http://www.eeworld.com.cn/circuit/upload/dda73ac31da3e7cca4f82e5788faba5e/6f138f9d410aa9080e2312606c06b4c1.jpg)
Clock: external crystal oscillator (2)
![STM32F1 and minimum system circuit diagram](http://www.eeworld.com.cn/circuit/upload/dda73ac31da3e7cca4f82e5788faba5e/777d94c8116d302e702c7ca41e8424c0.jpg)
Boot startup mode selection
![STM32F1 and minimum system circuit diagram](http://www.eeworld.com.cn/circuit/upload/dda73ac31da3e7cca4f82e5788faba5e/8e0565ce0e7e636f083b67e7f72e4fbd.jpg)
Download circuit (serial/JTAG/SWD)
![STM32F1 and minimum system circuit diagram](http://www.eeworld.com.cn/circuit/upload/dda73ac31da3e7cca4f82e5788faba5e/7f7d37feb497e50adb26427b5d6aa1b2.jpg)
Backup battery
- Analysis of the working principle of switching regulator
- The basic principles of power supply design. What are the key components of a power supply?
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- Visible laser digital control modulation driver
- 0.7~24V continuously adjustable current limiting power supply
- MIC4680 constant current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade Electric Bike Fast Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
