Three-phase electricity meter wiring circuit diagram
Source: InternetPublisher:念慈菴 Keywords: Power supplyAC/DC Updated: 2020/10/08
The following figure shows the three-phase watt-hour meter wiring diagram and wiring method:
![Three-phase electricity meter wiring circuit diagram](http://www.eeworld.com.cn/circuit/upload/9d298ecd758186d316906b2e7c2073c4/ed95914c1d8b2aa4dcf9032328aa1dae.jpg)
Picture description: Three-phase watt-hour meter wiring diagram
The three-phase three-wire active watt-hour meter uses a structure in which two sets of driving components act on two aluminum disks (or one aluminum disk) mounted on the same rotating shaft. Its principle is exactly the same as that of a single-phase watt-hour meter.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Build a simple buck-boost regulator and test it on a breadboard
- Fabrication of multi-cell lithium battery charging circuit
- Driving circuit of switching power supply field effect tube
- Energy-saving motorcycle rectifier regulator
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- Principles and precautions of active discharge circuit
- Adjustable voltage power socket
- The production of adjustable voltage-stabilized power supply composed of LM317
- Principle of single live wire power taking circuit
- Sense amplifier circuit
- Two-wire remote AC electronic thermostat (gas or oil furnace control)
- Three-phase phase loss alarm light circuit
- Power circuit of STR5412
- Interface circuit diagram for controlling AC load
- 3v to 5v circuit diagram
- Power circuit of LBO-522 dual trace oscilloscope
- Timing switch AC power circuit
- Recording level power supply circuit
