Harmonic distortion tester circuit
Source: InternetPublisher:newlandmark Keywords: Power supply other power circuits Updated: 2020/08/22
This new type of igniter attracts automobile manufacturers and users with its advantages such as low fuel consumption, low fuel consumption, and high output power. Its working principle is shown in the figure. When the piston in the automobile cylinder reaches the top dead center, a magnetic field in the distributor acts on the Hall circuit and outputs a low level. At this time, the current flowing through the resistor Ri and the island changes direction and flows into the Hall circuit H, so the transistors VT1 and VT2 are cut off. The magnetic energy stored in L oscillates in the L and G circuits, forming an alternating voltage of more than 200V. After this voltage is boosted by the ignition coil, a high voltage of 15kV is generated to ignite the fuel in the cylinder. As the engine rotates, the above process repeats itself.
- Benefits of Wide Bandgap Technology for Power Converters
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LNK304 non-isolated LED light string driver circuit
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- Adjustable regulated power supply with current limiting protection
- Battery powered switching circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
