Programmable measurement amplifier PGA circuit principle diagram
Source: InternetPublisher:萌面大虾 Keywords: Power supply other power circuits Updated: 2020/06/18
The programmable measuring amplifier has additional analog switches and drive circuits than the measuring amplifier. The gain selection switches Sl-S'l, S2-S'2, S3-S'3 operate in pairs. Only one pair of switches is closed at each moment. When the digital input code is changed, the closed switch number can be changed, and the selected Different feedback resistors are equivalent to automatically changing the resistance of the potentiometer R1 in the measurement amplifier to achieve the purpose of changing the amplifier gain.
![Programmable measurement amplifier PGA circuit principle diagram](http://www.eeworld.com.cn/circuit/upload/3c0d4f5aabc25c0f80b5685fb3eac690/10262f3b8fdc1a143bfc33b5ff3d5a54.jpg)
Transfer files for PCB proofing
The figure below shows the internal circuit schematic diagram of the integrated programmable measurement amplifier circuit chip LH0084. On the one hand, the feedback resistor of the operational amplifier A3 is selected through wiring to determine the basic amplification factor of the amplifier. On the other hand, automatic control of the amplification factor is achieved by controlling the analog switch.
![Programmable measurement amplifier PGA circuit principle diagram](http://www.eeworld.com.cn/circuit/upload/3c0d4f5aabc25c0f80b5685fb3eac690/da7c3b2db89aa2e63b077a2377bcf60d.jpg)
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Recommended circuits for different power on times of LM4911
- Switching power supply circuit composition and function introduction of each part
- Parallel DC regulated power supply circuit diagram
- Boost drive circuit composed of RT8450
- CNC regulated power supply production
- MIC4680 constant current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
