Ultrasonic proximity sensor circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Amplifiers power supplies and other power circuits Updated: 2020/01/29
A 100kΩ potentiometer R4 regulates the current feed to the solid tone generator. Adjust the potentiometer to the point where the speaker can produce sound. A single-transistor audio amplifier Q1 is coupled to the positive terminal of the speaker, and the output of Q1 is supplied to a voltage doubler circuit. The DC output of the voltage doubler drives the base of Q2.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- A very convenient small power supply circuit to share
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Op amp power supply decoupling bypass measures
- Constant current LED lamp driver circuit with soft start and anti-shock
- Parallel DC regulated power supply circuit diagram
- Boost drive circuit composed of RT8450
- Dynamic power supply for power amplifier controlled by thyristor
- Design of electric vehicle charger
- Variable gain operational amplifier circuit diagram
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Adjustable output voltage regulator circuit diagram
- Ultrasonic proximity sensor circuit
- A crystal controlled local oscillator circuit diagram
- OTL low frequency power amplifier circuit
