CMOS touch circuit
Source: InternetPublisher:石榴姐 Keywords: Sensors power supplies and other power circuits Updated: 2021/08/12
The touch circuit can be used with battery powered circuits. Schmitt trigger IC1 constitutes a 100kHz oscillator, IC2 is biased into the linear region, and then amplifies the output, and then charges C1 through the diode. IC2b acts as a level detector. When the sensor is touched, the oscillator signal is severely attenuated, causing C1 to discharge and IC2b to change its state.
- Benefits of Wide Bandgap Technology for Power Converters
- What kind of circuit is a voltage regulator circuit?
- Op amp power supply decoupling bypass measures
- LED Driver ZD1680
- Charging control circuit made by solar energy
- Homemade low-power UPS
- Adjustable voltage power socket
- Converting a lithium battery charging board into a constant voltage and current charger
- MIC4680 constant current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- The true meaning of pressure sensor
- Interface technology circuit analysis of sensors used in ESP
- Car ignition circuit diagram based on FM484 magnetic induction
- Hall switch integrated sensor appearance and typical application circuit diagram
- Identification sensor amplification circuit diagram
- Sensor amplification circuit diagram
- Microcomputer circuit compatible with sensor
- Bridge sensor transmit/receive circuit
- Sensor and AD7710/7712 signal conditioning ADC circuit
- The sensor and AD694 form a 4 to 20mA transmitter circuit
