Dual-frequency oscillation circuit diagram composed of audio decoder
Source: InternetPublisher:清宁时光 Keywords: Power supply other power circuits Updated: 2020/10/18
567 is an audio decoder, mainly used in automatic telephone systems to identify incoming telephone tones. The core of the integrated block is a high-reliability, high-precision phase-locked loop. According to the connection method and component values used in the figure, the two output signal frequencies are 1.5kHz and 4kHz respectively. As shown in the figure below:
- Basic circuit description of adjustable voltage regulator LM317
- Use pulse width modulation to get a precise output voltage
- Driving circuit that controls LED brightness using PWM signal
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED Driver ZD1680
- Low cost and high performance LED constant current power supply
- Power supply circuit that can reduce LM317 ripple
- Constant current charger using light emitting diode as voltage regulator
- Homemade Electric Bike Fast Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
