infrared receiver
Source: InternetPublisher:他们逼我做卧底 Keywords: Power communication power Updated: 2021/09/24
![infrared receiver](http://www.eeworld.com.cn/circuit/upload/545c7860c5e4450c94c9d101ae3112d6/d44f87378afcac9b2318382a49a48f51.gif)
This circuit has one of the simplest IR receivers you can make with cheap parts. The layout is not critical, a 9V battery will last a long time.
- How about the boost converter TPS61299?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- What kind of circuit is a voltage regulator circuit?
- Driving circuit that controls LED brightness using PWM signal
- LED rechargeable flashlight circuit diagram
- Homemade low-power UPS
- Car power 1.5V-12V six-speed converter
- Converting a lithium battery charging board into a constant voltage and current charger
- Portable device charging power circuit design
- 3v to 5v circuit diagram
- Warm current power circuit a
- Super Class A power amplifier power circuit
- led drive power circuit
- Music power circuit
- DC-DC conversion power supply circuit
- 5V uninterruptible power supply circuit
- COMPAQ 420G type SVGA color display power supply circuit
