Capacitance measuring instrument circuit
Source: InternetPublisher:张七岁 Keywords: Power supply other power circuits Updated: 2021/09/20
This measuring instrument can measure capacitance from several pF to 0.1uF, and the range is divided into five levels: 25pF, 100pF, 1000pF, 0.01uF and 0.1uF. Since the measurement principle is linear, it can be read directly using the ammeter scale.
When VT4 is turned on, the measured capacitor Cx and diode VD discharge. When VT4 switches once, the measured capacitor is charged and discharged once. The capacitance being measured is large, and more electricity passes through the ammeter each time it is charged; in addition, VT4 switches more times per second, and more electricity passes through the ammeter per second. The amount of electricity passing through the ammeter per second is the current flowing through the ammeter. Therefore, the current through the ammeter is proportional to the capacitance being measured, and proportional to the switching frequency of VT4. If the current passing through the ammeter is required to be the same, then the switching frequency of VT4 must be higher when measuring small capacitors.
- How to ensure the stable performance of SSD when the voltage is unstable?
- Schematic diagram of car cigarette lighter to USB power port
- What kind of circuit is a voltage regulator circuit?
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- LNK304 non-isolated LED light string driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- Dynamic power supply for power amplifier controlled by thyristor
- Design of temperature detection circuit implemented by single chip microcomputer
- Teach you a thyristor dimming LED drive power circuit design
- About the working principle of single touch mode light switch
- Design of data transmission interface circuit for a car driving recorder
- Those classic analog circuits worth collecting
- Single chip multi-microcomputer system sharing RAM circuit
- ×100L161 operational amplifier
- AD7982 differential conversion single-ended signal circuit diagram
- 90V/10A high power amplifier
- melody circuit
