Analog electronic circuits that electronics enthusiasts must know
Source: InternetPublisher:黄土马家 Keywords: Power supply other power circuits Updated: 2021/04/14
This article mainly summarizes 10 analog electronic circuits, I hope it will be helpful to your learning.
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/b031f5dc8f6c601904805cbb1e50a50e.jpg)
1. The function of each component of the circuit, the purpose of the circuit, and the characteristics of the circuit.
2. Analysis of the working principle of the circuit. How to amplify differential mode signals and suppress common mode signals.
3. The circuit’s single-ended input and double-ended input, single-ended output and double-ended output working modes.
2. Field effect tube amplifier circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/a93531b09fdde696305efc6eef8ea0d6.jpg)
1. The classification, characteristics, structure, transfer characteristics and output characteristic curve of field effect transistors.
2. Characteristics of field effect amplifier circuit.
3. Application occasions of field effect amplifier circuit.
3. Frequency-selective (bandpass) amplification circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/ffdd863e2e88c5db3395fc6c2206bb1b.jpg)
1. The function of each component:
Features of frequency selective amplifier circuit:
The function of the circuit:
2. Calculation of characteristic frequency:
Selection of frequency selection component parameters:
3. Amplitude-frequency characteristic curve:
4. Operational amplifier circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/42a41895686512659a00787d32a7bcf4.jpg)
1. The concept of ideal operational amplifier:
The input terminal of the op amp is virtually short-circuited:
Virtual circuit break at the input of the op amp:
2. The main uses of the inverting input mode op amp circuit:
The phase relationship between the input voltage and the output voltage signal is:
3. The gain expressions in the non-inverting input mode are:
The input impedances are:
The output impedances are:
5. Differential input operational amplifier circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/4272e2879fa1fce81fd8fdbb771dc911.jpg)
1. Characteristics of differential input operational amplifier circuit:
use:
2. The relationship between the output signal voltage and the input signal voltage:
6. Voltage comparison circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/d94c2b469a4f640f313a72d32092b728.jpg)
1. The function of voltage comparator:
The working process is:
2. Input-output characteristic curve of the comparator:
3. How to construct a hysteresis comparator:
7. RC oscillation circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/01046c513768413adb50c7f940d6058e.jpg)
1. Composition of oscillation circuit:
The function of the oscillator circuit:
Phase conditions for the oscillation of the oscillator circuit:
Oscillation circuit start-up and balance amplitude conditions:
2. The relationship curve between RC circuit impedance and frequency:
Phase versus frequency curve:
3. Analysis of phase conditions of RC oscillation circuit:
Oscillation frequency:
How to choose components:
8. LC oscillation circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/281f1362ef2aed39625fc029788be4d2.jpg)
1. Analysis of oscillation phase conditions:
2. DC equivalent circuit diagram and AC equivalent circuit diagram:
3. Calculation of oscillation frequency:
9. Quartz crystal oscillator circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/f9b20a68971b4f5b858939e0ebfa3e9f.jpg)
1. Characteristics of quartz crystal:
Equivalent circuit of quartz crystal:
Characteristic curve of quartz crystal:
2. Characteristics of quartz vibrator:
3. Oscillation frequency of quartz crystal oscillator:
10. Power amplifier circuit
![Analog electronic circuits that electronics enthusiasts must know](http://www.eeworld.com.cn/circuit/upload/9a01b2fcb2f0ef6713263fcfbff81968/c1a85bd8fc4d84858c82a4e72842c217.jpg)
- Build a simple buck-boost regulator and test it on a breadboard
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Principles and precautions of active discharge circuit
- LNK304 non-isolated LED light string driver circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- 0.7~24V continuously adjustable current limiting power supply
- MIC4680 constant current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
