A microcontroller infrared asynchronous communication port circuit diagram
Source: InternetPublisher:张三叔 Keywords: Power communication power Updated: 2020/12/04
The circuit introduced in this article was originally an actual circuit used for time adjustment and meter reading in a time-sharing electric meter. It is both simple and practical. Use infrared light transmitting tube sir-563 and infrared light receiving ic tube rpm6938 to realize the function of receiving and sending point signals, which can realize half-duplex two-way communication function. The communication distance is about 10 meters, and the asynchronous communication baud rate is 1200.
![A microcontroller infrared asynchronous communication port circuit diagram](http://www.eeworld.com.cn/circuit/upload/74afce5e668867a4f49f234db33d48aa/a3440498d2d031ff818e26c07393b090.jpg)
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Visible laser digital control modulation driver
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED Driver ZD1680
- LED rechargeable flashlight circuit diagram
- Principles and precautions of active discharge circuit
- LNK304 non-isolated LED light string driver circuit
- CNC regulated power supply production
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade home inverter circuit diagram
- Portable device charging power circuit design
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Warm current power circuit a
- Simple dual-channel variable DC power supply circuit
- Diamond differential input power amplifier power circuit
- audio power circuit
- AC-DC conversion power supply-inverter power supply circuit
