Same line automatic recording appender circuit diagram
Source: InternetPublisher:已注销 Keywords: Power supply other power circuits Updated: 2021/04/19
The same-line automatic recording adapter circuit is shown in the figure below. The same-line automatic recording adapter can be easily used on different types of domestic and foreign recording telephones and answering machines. Due to the limitations of the power supply and volume of the original machine, it is best to choose small and sensitive relays, such as Nissan SV-5 and M4-5. It is best to install this device on a fully automatic tape recording telephone. The modification effect is not obvious on an IC language chip type recording telephone.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Fabrication of multi-cell lithium battery charging circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LNK304 non-isolated LED light string driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A simple positive and negative power supply circuit
- A small and easy-to-make fast charger
- 3~15V 10A adjustable voltage regulated power supply
- Electric bicycle battery charger circuit
- Constant current charger using light emitting diode as voltage regulator
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
