CMOS line receiver
Source: InternetPublisher:张七岁 Keywords: Power supply other power circuits Updated: 2020/11/10
The trip point is set halfway between the R1 and R2 supplies; R3 provides over 200mV of hold-up for enhanced noise immunity. The maximum frequency of operation is approximately 300kHz. If TTL level feedback is required, change R2 to 39K. The trigger point is centered at 1.4V.
- Benefits of Wide Bandgap Technology for Power Converters
- Use pulse width modulation to get a precise output voltage
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED Driver ZD1680
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- Low cost and high performance LED constant current power supply
- Dynamic power supply for power amplifier controlled by thyristor
- Constant current charger using light emitting diode as voltage regulator
- Homemade home inverter circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
