Battery fast charging control integrated circuit design
Source: InternetPublisher:D先生 Keywords: Power charging circuit Updated: 2021/12/03
Circuit principle: The circuit provides +5V power supply voltage by a transformer, diode and voltage regulator IC7805. The battery voltage is divided by resistors R5 and R6 and then sent to the BAT end of the chip to provide a sampling voltage. The resistance of the resistor voltage divider network input to the BAT terminal should not be less than 200kΩ. When the TM terminal is grounded, the corresponding fast charge charging rate is 1C and the fast charge replenishment time is 80 minutes.
![Battery fast charging control integrated circuit design](http://www.eeworld.com.cn/circuit/upload/781b3ea0e0a3d3e12e92b63fe66ecd0a/50e90359f5142f9648b97e3aae452ca7.jpg)
- Schematic diagram of car cigarette lighter to USB power port
- Basic connection circuit of signal and power supply composed of ISOll3
- Use pulse width modulation to get a precise output voltage
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Design of electric vehicle charger
- Mc34063 MP3 Switching Charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- variable gain amplifier
- Lead-acid battery charger circuit schematic diagram
- Power supply circuit design optimized for digital light projectors
- Power circuit a composed of intelligent thyristor modules
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Single phase thyristor slotless nickel plated power circuit
- ±15V active servo power circuit
- Common power circuits and applications 07
- Common power circuits and applications 04
- Common power circuits and applications 01
