A circuit diagram for channel monitoring using AD5380 multi-channel DAC
Source: InternetPublisher:狂妄火龙果 Keywords: Power supply other power circuits Updated: 2021/06/23
In multi-channel DAC systems, being able to monitor all outputs from a single point is very beneficial for troubleshooting and diagnostic analysis. The circuit described in this article utilizes a single-channel SAR type ADC to implement output channel monitoring of a multi-channel DAC.
The AD5380 is a complete 40-channel, 14-bit DAC powered by a single power supply. All 40 channels feature a rail-to-rail on-chip output amplifier. The AD5380 has a built-in channel monitoring function, which is implemented by a multiplexer addressed through the serial interface. Any channel output can be routed to the monitoring output (MON_OUT) pin for monitoring with an external ADC. For any channel to be routed to MON_OUT, the channel monitoring function must first be enabled in the control register. The microcontroller or processor can select the output channel to be monitored through its serial output port and then read the ADC converted data through its serial input port.
The circuit diagram shown below utilizes the internal multiplexer of the 40-channel, 14-bit DACAD5380 to allow all 40 output channels to be individually routed to a single output (MON_OUT) pin, which is then routed through an external ADC (AD7476). monitor. This approach utilizes far less circuitry than would be required to monitor each channel individually.
- The basic principles of power supply design. What are the key components of a power supply?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Visible laser digital control modulation driver
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED rechargeable flashlight circuit diagram
- A simple positive and negative power supply circuit
- A novel and practical DC low voltage stabilized power supply
- 3~15V 10A adjustable voltage regulated power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
