Typical channel monitoring circuit diagram
Source: InternetPublisher:张小哥 Keywords: Power supply other power circuits Updated: 2021/03/19
In multi-channel DAC systems, being able to monitor all outputs from a single point is very beneficial for troubleshooting and diagnostic analysis. The circuit described in this article utilizes a single-channel SAR type ADC to implement output channel monitoring of a multi-channel DAC.
The circuit diagram shown below utilizes the internal multiplexer of the 40-channel, 14-bit DACAD5380 so that all 40 output channels can be individually routed to a single output (MON_OUT) pin and then through an external ADC (AD7476) monitor. This approach utilizes far less circuitry than would be required to monitor each channel individually.
![Typical channel monitoring circuit diagram](http://www.eeworld.com.cn/circuit/upload/8a4481a73335ec5e69221bf02c964323/c73732653b7951e6ff09a11629f3d4ef.jpg)
- How to Make a Soft Latch Circuit
- Schematic diagram of car cigarette lighter to USB power port
- Energy-saving motorcycle rectifier regulator
- Basic connection circuit of signal and power supply composed of ISOll3
- Switching power supply circuit composition and function introduction of each part
- Parallel DC regulated power supply circuit diagram
- CNC regulated power supply production
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
