A frequency meter circuit diagram composed of CD4046
Source: InternetPublisher:已注销 Keywords: Power supply other power circuits Updated: 2020/09/29
CD4046 is a general-purpose CMOS phase-locked loop integrated circuit. It is characterized by a wide power supply voltage range (3V-18V), high input impedance (about 100MΩ), and low dynamic power consumption. The power consumption is only 600μW when the center frequency f0 is 10kHz. , is a micro-power device.
The frequency meter uses the needle to indicate the level of the frequency being measured. R1 is composed of a 47k fixed resistor and a 51k potentiometer connected in series. R4, R5 and C4 form a low-pass filter. R3 is connected in series with the meter M and serves as the load of the source follower. R3 is also used to adjust the full-scale current of the meter. There is a large capacitor of 100LF on the meter head, which is used to eliminate the jitter of the meter needle at low frequencies. The measurement range of this frequency meter is 20Hz~1kHz.
The following is a frequency meter circuit diagram composed of CD4046 released by Shenzhen Jieduobang PCB Circuit Board Company.
![A frequency meter circuit diagram composed of CD4046](http://www.eeworld.com.cn/circuit/upload/60ed1d9f807102346a78a304fe4a6dc6/b79fcf5b3ac34dad7fcd7cd70771b351.jpg)
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Benefits of Wide Bandgap Technology for Power Converters
- Transformerless AC-DC constant current LED driver circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- The constant current source composed of two transistors can drive high power
- LED rechargeable flashlight circuit diagram
- Charging control circuit made by solar energy
- Car Audio Power Supply
- Homemade Electric Bike Fast Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
